Non Secure connection warning message
Rocko
Hi, I have noticed a warning on the address bar when I am using my PlusNet webmail account. This is a "Not secure HTTPS" warning that also indicates that there is a problem with the site's certificate and that some page content is not encrypted. Can anyone tell me if this is a big problem or if there is a fix? Many thanks.
7 REPLIES 7
Fixes: 1,552
Re: Non Secure connection warning message
Hi there. We've tested this and the https seems to be working fine for webmail.
Do you experience this issue using a different browser and device?
Rocko
Hi Gandalf, I am using MS Edge browser with windows 10 OS version 1803 on a laptop. When the webmail loads initially no error is displayed on the address bar, this only appears when an email is selected. Does this help? Cheers Rocko.
SammyM
Fixes: 84
Hello @Rocko,
Thanks for getting back to us. Please can you try both a different browser and device, and get back to us with the result.
 Sammy M - Sheffield Team
bobpullen
Fixes: 291
What sort of HTTPS warning are you seeing? If it's a mixed content warning like the one below, then that's to be expected if the email you've selected is calling remote images etc. over HTTP:
Rocko
Hi Bob, thanks for the reply, the error is displayed on emails with remote images but I have also noticed it on others, the PlusNet community home page for example.
The error is : Be Careful here
Some content on this page is not encrypted, which makes it possible for others to see or change the information you share with this site.
The thing is I don't remember seeing this before.
What do you think?
Many thanks Rocko
Rocko
Hi Gandalf, sorry about the delay in my reply. I have had the same error displayed when I logged on with fire tablet using the silk browser "Your connection to this site is not fully secure" Does this pose a threat of any kind? Many thanks
bobpullen
Fixes: 291
It will happen on the Plusnet Community Site for a similar reason i.e. if somebody is using a remotely hosted HTTP image for their avatar. That said, https://community.plus.net is not showing warnings for me at the moment when using MS Edge?
