Newbie question
- Everything else
- Re: Newbie question
Newbie question
03-01-2013 5:15 PM
I have a domain name via Plusnet and I want to use it to point to my wordpress.com website.
How do I do this?
How do I do this?
Message 1 of 6
(2,026 Views)
5 REPLIES 5
Re: Newbie question
03-01-2013 8:10 PM
Wordpress.com has a page on how to Map a Subdomain.
They also have instuctions to Map an Existing Domain, however, it seems less useful and I don't believe that it's possible with PlusNet (no way to change the nameserver).
To configure the domain from PlusNets side, you'll need to login to the portal and configure the domain via the 'Domain Names' page.
Message 2 of 6
(682 Views)
Re: Newbie question
03-01-2013 8:20 PM
I've been on the plusnet domain page but I really have no idea what I need to enter.
Message 3 of 6
(682 Views)
Re: Newbie question
03-01-2013 9:15 PM
You'll need to Configure your domain, then Configure DNS records, this is where you add the CNAME entry mentioned in step 1 of the wordpress instructions.
for example: Creating a new DNS record
will result in blog.yourdomain.com going to yourblog.wordpress.com.
Left Field | Type | Right Field |
blog | CNAME | yourblog.wordpress.com |
Message 4 of 6
(683 Views)
Re: Newbie question
03-01-2013 10:51 PM
I think a trailing dot would be needed on the right hand side of the right field to stop yourdomain.com being added.
Alternatively do you have CGI space with Plusnet where you could install WordPress yourself?
David
Message 5 of 6
(683 Views)
Re: Newbie question
04-01-2013 8:45 AM
Right finally got it to work, didn't realize I had to enable CGI too
Thanks for your help.
Message 6 of 6
(683 Views)
