Newbie at Plusnet - Website info
FIXEDTopic Options
- Everything else
- Newbie at Plusnet - Website info
10-02-2014 4:32 PM
Hi
I'm in the process of having PlusNet business installed. Have a few questions re website:
1. I have an 'allowance' of 250 for the website........how does this translate in number of pages etc?
2. What can I have or not have on the website (not talking about content, but the technical side)?
3 Any recommendations for compatible website template sites or website creator programmes (high end!)?
4. Are there any user sites you can direct me to?
Thanks for your help!
Fixed! Go to the fix.
Message 1 of 2
(814 Views)
1 REPLY 1
10-02-2014 5:01 PM
Hi there!
It doesn't translate directly as it depends on the contents of your site. If it's your first website and you're not adding anything too content-heavy like embedded videos, flash games or applets etc I'd not worry.
Your package allows for HTML based hosting, that would tend to mean text and images, so nothing too fancy but you should still be able to do a fair bit with setting up your first site.
The included hosting isn't particularly high-end but Adobe Dreamweaver is good for attacking HTML from the angle of a visual layout of the site rather than working with just the code.
Not strictly, but here's links to some links which should lead to a few examples of Dreamweaver designed websites.
http://forums.adobe.com/thread/431274
Quote 1. I have an 'allowance' of 250 for the website........how does this translate in number of pages etc?
Quote 2. What can I have or not have on the website (not talking about content, but the technical side)?
Quote 3 Any recommendations for compatible website template sites or website creator programmes (high end!)?
Quote 4. Are there any user sites you can direct me to?
Message 2 of 2
(209 Views)
- Everything else
