New ccgi site - session save path?
- Everything else
- New ccgi site - session save path?
17-03-2010 3:04 PM
Is the "session.save_path" really /var/lib/php5 as stated in PHPInfo? Shouldn't it be somewhere like /tmp? I know it can be redirected by a local php.ini but I've never had an issue before the upgrade.
Stuart
Stuart
Message 1 of 6
(1,055 Views)
5 REPLIES 5
Re: New ccgi site - session save path?
17-03-2010 3:38 PM
That's a good point, looks like we missed that one. We'll look in to it.
Message 2 of 6
(334 Views)
17-03-2010 3:58 PM
Quote from: stuartp Is the "session.save_path" really /var/lib/php5 as stated in PHPInfo?
That's standard for Debian. It should have slightly odd permissions to guard against fishing, but "should" work.
Gabe
Message 3 of 6
(334 Views)
17-03-2010 4:07 PM
It would be fine on a single box, but as there's four cgi servers behind a loadbalancer you would get unexpected results using that on our platform. /tmp is shared across all the boxes so that's a much better place for it.
Message 4 of 6
(334 Views)
17-03-2010 4:40 PM
Quote from: Ben It would be fine on a single box
It would be fine if it was shared, but if it isn't then that explains it. Sessions now world readable in tmp. Hey ho.
Gabe
Message 5 of 6
(334 Views)
17-03-2010 4:54 PM
They shouldn't be world readable, they will be group readable, which is similar on this platform as everyone's in the same group. I'd recommend people set it specifically, but having it in /tmp will work. Platforms with so many different users on are always challenging to lock down without killing too much functionality.
Message 6 of 6
(334 Views)
- Everything else
