New Webspace Problem
- Everything else
- Re: New Webspace Problem
13-02-2008 1:34 PM
Hi
Forgive me if this is an idiotic question, but I'm new here!
I am using Dreamweaver MX 2004 to create and upload to my webspace. I have uploaded 2 webpages, including the default Index.html page.
If I go to check the website is there (at www.benchmark-joinery.co.uk), it flashes up the homepage (index.html) for a second or so, then switches to http://webspace/plus.net/webspace_plusnet.html. ; There is a message at the top that says that the web address has not yet had a web page uploaded to it! Then after a while it goes to the www.plus.net website.
Am I doing something stupid?
I would appreciate any advice!
Sue
Sue
Message 1 of 6
(1,781 Views)
5 REPLIES 5
13-02-2008 1:41 PM
Quote including the default Index.html page.
Due to the setup of our homepages server you might want to use all lower case. Without even looking at your webspace I'm assuming that there is an Index.html (yours) and an index.html (ours) {note the lowercase 'i'}. If you remove our index.html file, or rename yours to index.html (with a lowercase 'i') this should work.
Message 2 of 6
(559 Views)
13-02-2008 1:50 PM
Thanks for your reply Chris. Sorry, but I just automatically capitalised the I in index: The actual file is index.html. Nevertheless, I did delete the uploaded page and try again. Unfortunately, I am still experiencing the same problem.
Hope you can advise!
Sue
Sue
Message 3 of 6
(559 Views)
13-02-2008 1:54 PM
Hmm, I'll go and have a look
Message 4 of 6
(559 Views)
13-02-2008 2:04 PM
Do you have a line similar to this in your html?
If so, take it out and reupload the page
<meta http-equiv="refresh" content="1;url=http://webspace.plus.net/webspace_plusnet.html">
Message 5 of 6
(559 Views)
13-02-2008 2:18 PM
Many thanks, not sure how that got there!!!
However, it is now gone, the problem is solved and I can get some brownie points!!!!
God, you're good!!!!!!!!!
Sue
Sue
Message 6 of 6
(559 Views)
- Everything else
