New CGI platform is?
- Everything else
- New CGI platform is?
01-04-2014 9:42 PM
Does anyone know which OS and version the new CGI platform runs on?
I've got some C programs I need to run on it, so knowing or being able to determine the version of libc would be very useful.
Mike
Re: New CGI platform is?
01-04-2014 10:06 PM
GNU C Library stable release version 2.2.5, by Roland McGrath et al.
Copyright (C) 1992-2001, 2002 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
Compiled by GNU CC version 3.2.2.
Compiled on a Linux 2.4.19 system on 2004-11-23.
Available extensions:
GNU libio by Per Bothner
crypt add-on version 2.1 by Michael Glad and others
Berkeley DB glibc 2.1 compat library by Thorsten Kukuk
linuxthreads-0.9 by Xavier Leroy
NoVersion patch for broken glibc 2.0 binaries
BIND-8.2.3-T5B
libthread_db work sponsored by Alpha Processor Inc
NIS(YP)/NIS+ NSS modules 0.19 by Thorsten Kukuk
Report bugs using the `glibcbug' script to <bugs@gnu.org>.
Looks old :o... can anyone guess the distro?
01-04-2014 10:35 PM
Quote Linux central.aber.ac.uk 3.10.25-gentoo #2 SMP Thu Jan 16 11:22:40 GMT 2014 x86_64 Intel(R) Xeon(R) CPU L5420 @ 2.50GHz GenuineIntel GNU/Linux
Quote Linux thunderbolt 3.13-1-amd64 #1 SMP Debian 3.13.5-1 (2014-03-04) x86_64 GNU/Linux
Quote Linux server-119570 3.2.0-58-virtual #88-Ubuntu SMP Tue Dec 3 17:58:13 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
01-04-2014 10:36 PM
If I'm right, SuSE 8.1, released in 2002-09-30 and supported until 2005-01-31 hardly makes this a great modernisation!
02-04-2014 9:06 PM
Quote from: avatastic Can you execute a 'uname -a' from a perl script? That may tell you.
Sadly not:
/bin/uname: Permission denied
04-04-2014 11:49 AM
Quote from: MikeMcTernan Does anyone know which OS and version the new CGI platform runs on?
I'm pretty sure I knew the answer to this once upon a time but it now escapes me. I'll do some digging and get back to you...
Quote from: MikeMcTernan I've got some C programs I need to run on it, so knowing or being able to determine the version of libc would be very useful.
Looks like you now have this. I'll enquire whether or not it's possible to install a more recent revision.
07-04-2014 3:16 PM
Whilst I don't have the explicit OS version as yet, I can tell you that Hostopia use a fairly heavily modified distro. They tend to build most of their stuff from source and need to handle a very varied range of server requests (both Linux and Windows). It's important to note that we're not the only users of this particular server cluster/environment and the features of our CGI offering are fairly sparse compared to some of the other partner's set-ups.
Quote from: Bob
There's a larger piece of work (scheduled for the latter part of the financial year) to upgrade the server environment which would include things like coreutils and glibc. I can't give you a specific completion date for this work however it is on our partner's roadmap. At the moment an older version of glib is needed for backwards compatibility and to support legacy features that are part of the core environment.
09-04-2014 6:22 PM
Quote from: Bob Hostopia use a fairly heavily modified distro.
A sort of pick-n-mix (-n-hack) of SUSE/openSUSE distros. There's a bit of 11.2 (2009) in there, including the kernel, but a lot of the geek interface does date back to 2002. It is positively the weirdest environment I've met, but I guess they have tried very hard to make things as easy to use as possible for as many people as possible.
Quote There's a larger piece of work (scheduled for the latter part of the financial year) to upgrade the server environment which would include things like coreutils and glibc.
Meanwhile, any chance of an update to sqlite?
Gabe
10-04-2014 10:51 AM
Quote from: Gabe Meanwhile, any chance of an update to sqlite?
I'll enquire. I'm right to assume we're running 2.8.17 at the moment yes?
10-04-2014 5:44 PM
Gabe
