NetObjects Fusion 9, suggested FTP settings.
- Everything else
- NetObjects Fusion 9, suggested FTP settings.
10-10-2007 10:50 PM
This is not a request for help but the info here may help others.
For those of you using NetObjects Fusion web builder software or indeed any other web builder software with a built in FTP uploader facility.
You may be finding the built in uploader simply wont connect! I had same problem and hunted high and low for an answer.
I eventually stumbled on the correct settings by my own trials and lots of bad language.
I use Win XP SP2
ZA free edition
AVG free edition
Ad-Aware free edition
(there's a theme building here. . .)
NetObjects Fusion 9 (free coverCD version (excellent too, I am considering buying a full copy of v10))
The fact that all these software packages are the free versions means there are some bits 'missing' from them in comparison to full versions. Therefore my descriptions of some screens may differ from yours.
For the purpose of this message I will be quoting some details from my own ISP (Plusnet of UK). The details you will require in order to succeed will be different and can be obtained from your ISP/webHost and will be very similar. I hope you will see where the twists occur that are causing your problems.
You will no doubt have tried finding the EXACT details from your ISP / WebHost company so you can enter the required details in to the fields in the PUBLISH SETTINGS dialogue of FUSION. These details are most certainly wrong! Or at the best very best ambiguous and missleading. There is no continuity between ISPs naming conventions and Fusions conventions. If only there was . . .sigh. I have the answer. . .
OK, on with the fix.
You need to change two settings only. One in ZoneAlarm and one in Fusion.
1. In ZoneAlarm (free edition) go to FIREWALL, ZONES and add a new a new ZONE as follows.
Click ADD, then in ZONE field choose INTERNET, in HOST NAME input 'ftp.plus.net' in my case but you will enter your FTP details, in DESCRIPTION field put something like 'Plusnet FTP upload' (any text you like here), and finally click on the Lookup button and wait. ZA will search the web and find the related IP address for the HOST NAME you entered above. If successfull please click OK. If unsuccessfull then you have entered a false name in the HOST NAME field. Try again.
Now click APPLY and the bottom right hand side of the ZA screen (without doing this, nothing will work).
2. In Fusion go to PUBLISH and then click on PUBLISH SETTINGS.
Click NEW (even if you already have an FTP setting, we'll create a new one from scratch) (you can delete your old none-working profile if you like).
SERVER TYPE = FTP
PROFILE NAME = FTP Publish PLUSNET (you can input anything here)
SERVER = ftp.plus.net
DIRECTORY = /htdocs
User Name = your own ISP/Webhost login username here
Password = your own login password here.
The main difference you see in this profile and your own none-working profile is the Server Name and the Directory Name.
You probably have something like www.username.plus.com in Server Name and ftp.plus.net/htdocs as the Directory. That's just what I did!
Annoying or what!!!!
Save your Fusion session and exit. Relaunch and see what happens.
I will also post this on the Plusnet Forums somewhere.
Good luck. I hope it helps someone out there.
Ian
I use Win XP SP2
ZA free edition
AVG free edition
SERVER TYPE = FTP
DIRECTORY = /htdocs
Ian
Message 1 of 1
(1,472 Views)
- Everything else
