Nest thermostat 3-gen on 2704N
- Everything else
- Nest thermostat 3-gen on 2704N
05-08-2018 9:52 PM
I am struggling to connect my NEST thermo to a new plusnet router (2704N). I've tried to follow all the guidance from Nest but with no luck. Anyone else had similar problems?
tia!
Re: Nest thermostat 3-gen on 2704N
06-08-2018 9:33 AM
No problems connecting mine but how far is your thermostat from the router ?
06-08-2018 10:51 AM - edited 06-08-2018 10:58 AM
I know this wont help you, but I have no problem connecting mine using a BT Smart Hub with plusnet
Have you separated the 2.4 and 5 GHz Bandwidths etc. using the correct passwords. etc and tried connecting on either Bandwidth.
07-08-2018 10:59 AM - edited 07-08-2018 11:00 AM
The OP has a 2704 a.k.a single band Hub Zero.
07-08-2018 11:41 AM - edited 07-08-2018 12:00 PM
The OP will not be able to try on 5GHz then
- Everything else
