Nest thermostat 3-gen on 2704N
renton678
I am struggling to connect my NEST thermo to a new plusnet router (2704N). I've tried to follow all the guidance from Nest but with no luck. Anyone else had similar problems?
tia!
4 REPLIES 4
gleneagles
Aspiring Legend
Fixes: 17
Re: Nest thermostat 3-gen on 2704N
No problems connecting mine but how far is your thermostat from the router ?
We are born into history and history is born into us.
LifeonMars
Seasoned Pro
Fixes: 12
I know this wont help you, but I have no problem connecting mine using a BT Smart Hub with plusnet
Have you separated the 2.4 and 5 GHz Bandwidths etc. using the correct passwords. etc and tried connecting on either Bandwidth.
Fixes: 418
@LifeonMars
The OP has a 2704 a.k.a single band Hub Zero.
LifeonMars
Seasoned Pro
Fixes: 12
The OP  will not be able to try on 5GHz then  Grin
