Need some advice
Lorraine60
Need some advice
I have just started with Plusnet and for some reason when I go on to Netflix it tells me my internet is Not Connected, which it obviously is, as my laptop is working!
It worked well before I changed providers.
Please can anyone help, I like my Netflix especially on these long days 😞😷
6 REPLIES 6
Fixes: 1,483
Re: Need some advice
Moderators Note
This topic has been moved from Chat to Everything Else
Fixes: 1,483
Are you trying to access Netflix in your laptop or another device?
Is it a wired or wireless connection?
Lorraine60
Hi Dvorak,
No not from lap top, from tv.
It's a wireless connection.
Thanks for taking the time to reply
Fixes: 1,483
It might be a daft question, did you update the wireless settings on the TV when you switched to Plusnet?
Lorraine60
Hi again,
Not sure what I did, or pressed in the settings list but whatever I did, worked.
many thanks
Lorraine60
 Lol Not a daft Question...
That was Exactly what the problem was doh!
