Need A Specific Static IP Address
Harika43
Hi
I need a specific STATIC PUBLIC IP ADDRESS to be assigned to my PLUSTNET network. Currently, STATIC IP is being enabled but, it was assigned by ISP.
is it possible to setup a specific STAIC PUBLIC IP ADDRESS ( I'll provide this address to ISP ).
Thank you 🙂
Tags (1)
2 REPLIES 2
Fixes: 585
Re: Need A Specific Static IP Address
No it isnt. The static IP assigned must be from the IP ranges owned and routed by Plusnet.
greygit1
"Originally assiigned to" is a possibly better.
"Owned by", less so. Netblocks can be voluntarily relinquished. There's also (or used to be) a re-rental market in sub-blocks.
IMHO.
SWIP.
https://encyclopedia.thefreedictionary.com/Shared+WhoIs+Project
Sub-blocks can arrive on another providers routing tables. (I'm not implying Plusnet would).
And not as weird as carrier-grade NAT. My humble understanding is that is shouldn't be deployed at end-point use. But I could be wrong (I've seen private IP address space - 10's, 192's, etc.) used on intervening routing device interfaces in the past - on the public internets).
