Name servers for domain hosting
jon
My parents have previously had a custom domain hosted by plus net. I then switched them to another host but the domain is still showing under custom domains in the plus net control panel. I'd now like to switch back to plus net hosting (as the current host is losing emails they are forwarding) but I can't remember what name servers I used prevoiusly. What plus net name servers should I use?
Jon
3 REPLIES 3
spraxyt
Aspiring Legend
Fixes: 75
Re: Name servers for domain hosting
If the domain still shows in the Hosting Control Panel are you sure it was ever moved away from Plusnet? What does whois show as its IPStag?
The Plusnet name servers are ns1.force9.net and ns2.force9.net
David
jon
It was never registered with plus net, only hosted, the ipstag has always been LIVEDOMAINS (ukreg).
Yes I am sure I'm not currently using the plus net name servers.
Thanks for the information, I'll try that and see if it works.
Fixes: 143
If I understand things correctly, PlusNet's dropped hosting for new customers 17 Dec 17 and in response to a specific question I asked, that applies to any new hosting request for existing users as well.  Therefore you might find that you cannot return (repoint) the domain name to Plusnet.
