MySQL and PHP Versions
- Everything else
- MySQL and PHP Versions
02-06-2010 12:05 PM
Hi
I am considering setting up a Vanilla forum which has the following requirements
PHP version 5.2.0 or newer
Configuration
• file_uploads = on
Modules
• PHP Data Objects
• PDO_MySQL module must be enabled (some admins disable this, we don't know why)
• GD version 2.0 or newer (this is optional, but without it you cannot have profile pictures)
• cURL or Sockets to allow plugin sandboxing
MySQL version 5 or newer
Apache version 2 or newer
Configuration
• AllowOverride = All (this is optional, but it allows friendly urls)
Modules
• mod_rewrite (this is optional, but it allows friendly urls)
Is it possible to confirm whether these are all met/
Stuart
Configuration
• file_uploads = on
Modules
• PHP Data Objects
Configuration
Modules
Stuart
Message 1 of 2
(840 Views)
1 REPLY 1
Re: MySQL and PHP Versions
02-06-2010 12:32 PM
Assuming you are talking about ccgi http://ccgi.elvin.plus.com/misc/phpinfo.php will answer some (most?) of your questions.
Message 2 of 2
(271 Views)
- Everything else
