MySQL...What happens next?
- Everything else
- MySQL...What happens next?
02-03-2008 5:03 PM
I've activated MySQL on my account Friday night.
What happens next as I've had no email as yet unlike when I activated CCGI.
Is this a longer process?
Customer and Forum Moderator. Windows 10 Firefox 100.0.1 (64-bit (64-bit)
Re: MySQL...What happens next?
02-03-2008 9:33 PM
You have checked your spam folder?
02-03-2008 10:21 PM
I will try a reset and re-enable tomorrow if needed.
Nothing out of the ordinary in my spam folder.
Cheers
Dick
03-03-2008 12:01 AM
This was the response from PlusNet
Quote you cgi space is already active
Please check the CGI support section for help and information on the CGI service:
http://www.plus.net/support/webspace/cgi_php/
03-03-2008 8:46 AM
I'm pretty certain the password was just the same as my main account password for both of them, rather than being something different as the support docs imply.
03-03-2008 10:13 AM
Quote From: dbcreator@plus.net.uk
Date: 08/25/07 16:40:11
To: postmaster@*****.plus.com
Subject: Database Creation details
Dear Customer,
Congratulations, you have successfully set up your new MYSQL database account.You
are now one step closer to building powerful dynamically driven websites.To get you started
we suggest you take a look at some of the links detailed below and keep this e-mail safe
as it contains all of the details you need to log on successfully.
MYSQL Database Account Details
The Details of your MYSQL database account are as follows:
MySQL Host: humbug
Username: ********
Password: a23aea***1160271
DB Name: *****_pn
03-03-2008 10:19 AM
03-03-2008 10:23 AM
It is the same for CCGI, although if you change your portal password the ccgi one will stay as it was.
03-03-2008 11:30 AM
I'm currently at work so when I get home tonight I will check my Inbox.
If there is nothing I will re-enable MySQL.
03-03-2008 9:28 PM
Postini appears to be refusing Plusnet emails to Plusnet again with a 571 error.
This used to happen and was fixed.
04-03-2008 8:49 AM
04-03-2008 3:31 PM
Quote Thank you for getting back to us.
Unfortunately you will need to raise a ticket on the plusnet account as well, I appreciate that the account is yours however it would be breaching the data protection act if we where to release information such as this on another account.
We apologise for the inconvenience caused.
This is a joke, coming out with that, thay need to read the Data Protection Act.
04-03-2008 3:39 PM
What did you ask them to do?
If you asked them to give you the details for your F9 account on your PN account, then yes, the DPA is not relevant.
However, I'm always happier for them to be over-cautious with our data, rather than under-cautious!
Wouldn't it have been as fast to raise the ticket on the correct account? (Presuming thats the problem with the limited info you shared.)
04-03-2008 3:52 PM
I asked them for my PlusNet info on my F9 account regarding my CGI & MySQL space, and yes it would have been easier to open a new ticket.
Watt I am Going to do!
[Edit]
Update I have open a New ticket on my PlusNet account, ticket number 24348015
04-03-2008 4:14 PM
I manage a number of PN accounts, and whilst the Comms guys will often give bits of advice and theoreticals for each account, I still have to raise a ticket on the account I want something actioning on.
Its good for traceability (for both sides) and its a sensible security practice.
I can see your point, where they know the same person has a couple of accounts it should be possible to divulge the details, however, its a burden I'd rather not see the CS guys under.
So long as we raise the tickets on the right accounts, they are covered, and so are we.
Wrong to quote the DPA, but right to request you raise the ticket on the account you wanted to get details for IMO.
- Everything else
