MySQL OUTFILE exporting data
- Everything else
- MySQL OUTFILE exporting data
21-08-2007 12:28 PM
I'm quite new to the MySQL stuff and have searched the net for an answer to exporting (backup) all the data from a table.
I have tried the command localy (localhost) and it works fine but when i use the PlusMySQLAdmin interface it returns an error. Can someone help please?
Heres the command I'm using:
SELECT * INTO OUTFILE 'C:/backup.txt'
FIELDS TERMINATED BY ',' OPTIONALLY ENCLOSED BY '"'
LINES TERMINATED BY '\n'
FROM myTable;
FROM myTable;
Message 1 of 4
(2,272 Views)
3 REPLIES 3
Re: MySQL OUTFILE exporting data
21-08-2007 1:24 PM
Quote I have tried the command localy (localhost) and it works fine
Do you mean your own MySQL installation, if so is it version 4 like Plusnet?
Why don't you use the MySQL Dump program instead, it seems to be what most people use?
Message 2 of 4
(666 Views)
21-08-2007 1:27 PM
Like i explained, I'm faily new to this. Whats the MySQL dump?
Message 3 of 4
(666 Views)
21-08-2007 1:36 PM
I think I found it. Sorry had a blonde moment ???.
I've been going about it all the wrong way. I've been using command lines to develop my databases and should have realised that the wheel has already been invented....
Thanks for kicking my brain into gear.
Message 4 of 4
(666 Views)
- Everything else
