MySQL Details?
- Everything else
- MySQL Details?
MySQL Details?
06-09-2008 12:33 AM
Hey guys, I need some help or direction, I want to set up wordpress - But I can't get started as I don't know the MySQL user name or password.
It's been activated, but that was a while ago - and I don't have any emails with the info. Where can I get the info?
Thanks for reading
Thanks for reading
Message 1 of 4
(1,013 Views)
3 REPLIES 3
Re: MySQL Details?
06-09-2008 1:26 AM
Deactivate then reactivate and you will get a new email.
Same applies to ccgi activation email.
Also do a search for wordpress for important compatibility issues, and be aware that php files cannot be .htaccess protected on the ccgi.
Message 2 of 4
(185 Views)
Re: MySQL Details?
30-09-2008 8:54 PM
I just found your message - when you say ! " I don't have any emails with the info. Where can I get the info?"
Well you would of got the e-mail but they seem to send it to the catch all address. Suggest check via web mail.
BTW how far did you get with wordpress?
Message 3 of 4
(185 Views)
Re: MySQL Details?
30-09-2008 9:09 PM
@Flexing, did you get this sorted? If not I can reset your password for you if you like?
Message 4 of 4
(185 Views)
