My .htaccess file is casing me problems, what's wrong with it ?
- Everything else
- Re: My .htaccess file is casing me problems, what'...
27-03-2011 10:44 PM
My .htaccess file use to work ok but is now causing 500 error message page.
Could someone kindly tell me if they can see anything wrong with it or has something changed in plusnet web hosting to now cause me problems.
The file has the following:-
Order deny,allow
<Files .htaccess>
order allow,deny
deny from all
</Files>
ExpiresActive on
ExpiresDefault A31536000
RewriteEngine On
RewriteCond %{HTTP_USER_AGENT} Wget [OR]
RewriteCond %{HTTP_USER_AGENT} CherryPickerSE [OR]
RewriteCond %{HTTP_USER_AGENT} CherryPickerElite [OR]
RewriteCond %{HTTP_USER_AGENT} EmailCollector [OR]
RewriteCond %{HTTP_USER_AGENT} EmailSiphon [OR]
RewriteCond %{HTTP_USER_AGENT} EmailWolf [OR]
RewriteCond %{HTTP_USER_AGENT} ExtractorPro
RewriteRule ^.*$ deny.htm
ErrorDocument 301 http://mywebsite.co.uk/errors/error.htm
ErrorDocument 400 http://mywebsite.co.uk/errors/error.htm
ErrorDocument 403 http://mywebsite.co.uk/errors/forbidden.htm
ErrorDocument 404 http://mywebsite.co.uk/errors/error.htm
IndexIgnore *
Appreciate any help given
Regards Roy
Order deny,allow
<Files .htaccess>
order allow,deny
deny from all
</Files>
ExpiresActive on
RewriteEngine On
IndexIgnore *
Regards Roy
Message 1 of 5
(1,062 Views)
4 REPLIES 4
Re: My .htaccess file is casing me problems, what's wrong with it ?
27-03-2011 11:02 PM
Have you tried without the Expires lines. This is not a common option used and may not be permitted on Plusnets web servers.
Message 2 of 5
(386 Views)
27-03-2011 11:36 PM
Quote from: Peter Have you tried without the Expires lines. This is not a common option used and may not be permitted on Plusnets web servers.
Thank you very much for your quick reply.
I have just taken out the 2 Expires line and I can now see my web pages again
That's saved me a lot of trouble experimenting with various bits of the file
Regards roy
Message 3 of 5
(386 Views)
27-03-2011 11:45 PM
I'm surprised it works with the IndexIgnore line present; I thought that was disallowed, and it is set in the configuration so isn't needed.
David
Message 4 of 5
(386 Views)
30-03-2011 10:21 PM
Thanks Spraxyt for your reply.
Things seemed to be working with the IndexIgnore file in place but after your comment I did some more reading on the forum I thought it best to take it out. This meant you could then see inside my folders so I then set about reseting the file permissions.
Most of my web pages are htm files. My file permission are now set to:-
Folders - 0711
Files - 0644
Things seem to be working as I want them to.
Thanks for your help
Regards Roy
dick:quote
Folders - 0711
Files - 0644
Regards Roy
dick:quote
Message 5 of 5
(386 Views)
- Everything else
