My hosted websites are redirecting to plusnet
jonnyfriendly
Hi
Just checked 2 of my www sites hosted by plusnet and now when i put in the www address to browser they both redirect to Plusnet site
Have been working fine up until recently
Any suggestions ?
thanks in advance
j
10 REPLIES 10
Midnight_Caller
Re: My hosted websites are redirecting to plusnet
Are you certain that it is PlusNet home page I.E. this one:
http://www.plus.net ?
jonnyfriendly
Yes - ive just checked again.  I have 3 websites hosted with Plusnet  2 of which now lead me to plusnet
j
Chris
Legend
Fixes: 169
I've just checked the 3 domains on your account and all are directing correctly as far as I can tell. None of them sent me to the Plusnet website and they all direct to the relevant folders as they should.
Have you made any DNS changes locally or updated your hosts file at all?
jonnyfriendly
Not that i am aware of. Am getting this message when trying to connect via Firefox  www.godnose.co.uk uses an invalid security certificate. The certificate is only valid for the following names: *.plus.net, plus.net (Error code: ssl_error_bad_cert_domain)
j
jonnyfriendly
Have just tried connecting via link in my previous post and it works
Does this mean problem is at my end ? If so any ideas.
Ps.  the dognose website is working from my end, the others go to plusnet
j
jonnyfriendly
Sorry - ive just checked again they are all defaulting to Plusnet
j
Chris
Legend
Fixes: 169
Are you trying to browse to https://www.domain.co.uk?
picbits
I think Chris has sussed it maybe.
https:// goes to the PN page
http:// goes to the correct website
jonnyfriendly
Bingo!  Thanks Chris +Dom etc
I had loaded google which comes up as an https address and replaced the www etc with my address - hence the problem
As a matter of interest why does Google use https (not all websites do) and what is the difference to a http ?
I'd be interested to know
thanks again
j
spraxyt
Aspiring Legend
Fixes: 75
HTTPS supports secure (encrypted) connections; HTTP does not - all transmissions are in plain text. The Plusnet Webspace FAQ provides information on using HTTPS (SSL) to connect to your website using a secure connection. As you will see the format of URLs is different and domain addresses are not supported.
A separate SSL Security Guide expands on using SSL.
David
