My Network Places / Webspace
- Everything else
- My Network Places / Webspace
27-04-2008 3:46 PM
I am trying to get my webspace recognised by My Network Places in XP (SP2). Working through the "Add Network Place Wizard" I finish up being told the place is not acessible and that I might not have permission to use the network resource and to contact the administrator to find out if I have access permissions. I am the administrator. Finally the notice tells me that the Network path was not found.
If I want to use FP extensions webspace then there seems to be no problem. As I want to make the space available to people without FP I would welcome any help and advice.
Thanks.
Thanks.
Message 1 of 4
(1,123 Views)
3 REPLIES 3
Re: My Network Places / Webspace
27-04-2008 7:11 PM
Are you using ftp://ftp.plus.net/ as the address?
Message 2 of 4
(212 Views)
28-04-2008 12:23 PM
Thanks David,
I am a force9 client but the meothod worked.
Joe
Joe
Message 3 of 4
(212 Views)
13-05-2008 1:37 PM
You might want to keep ftp sites out of "my network places". Windows XP seems to "prod" ftp sites when explorer refreshes and IMO it can make things very laggy.
By all means put FTP shortcuts elsewhere but not MNP or Desktop.
Message 4 of 4
(212 Views)
- Everything else
