Multiple fibre lines?
weewards
I currently have a full fibre line to my premises and an analogue line with fibre broadband.
What happens after switch off of the copper line as I am told it is not possible to have two fibre lines to the same premises.
Apparently this is not a technical issue but an agreement/marketing issue.
28 REPLIES 28
tactilis
Re: Multiple fibre lines?
What is the reason you want two fibre lines?
Other solutions may be available if the actual problem to be solved is understood.
Fixes: 392
@weewards If you are thinking that you need a separate line line for the phone, you don't. You will get the phone service over the same line as your broadband, but it will be a VoIP   service i.e a digital one. What that means is that instead of your phone being plugged into the current Master Socket, it will be plugged into the rear of your router via  an adapter, and work exactly as it does now.
The only difference i that,, if you stay with Plusnet, you will need to take out a separate service with a VoIP provider. If you still want the phone with the same provider as your broadband, you will have to move to an ISP which does both. EE or Zen are two who do this - there will be others, but without further research I don't know which they are, but you can check this yourself by visiting other ISP's sites.
If you need further help, post back with your specific questions.
Fixes: 480
Moderator's note:
Thread moved from Broadband to Everything Else
Fixes: 254
This reads as a current solution to an unspecified problem.  Providing appropriate advice needs to be informed of why you have two lines now: do they both deliver broadband services?
Fixes: 118
@weewards
The copper line is used to supply "Fibre" along with a phone service.
In a victory for the marketing bods over common sense what we know as FTTC (SOGEA in the future) is known as "Fibre" whereas FTTP is "Full Fibre"
If you have two lines then I assume you have two accounts. It may be possible to move the Copper line to SOGEA so you still have two lines but, as stated, you need VOIP for the phone service. VOIP works on almost any internet connection.
weewards
I live in a multi generational household & my son in law works from home in a garden office. He has his own full fibre broadband & I have fibre broadband via the analogue phone line but when I contacted PlusNet a while back I was told that they cannot supply 2 full fibre circuits to the same address so I am concerned that when the copper wire is cut I won’t be able to have my own broadband.
Previously I was told I could upgrade to full fibre but in the process they cut off my son in law who is with BT, he wasn’t happy & it was then that I was told that PlusNet cannot supply 2 full fibre circuits to the same address.
Fixes: 118
@weewards
Put your phone number in the folowing.
Look to see if SOGEA is available and what does it say regarding Fibre Priority Exchange (Y/N)
Fixes: 392
@weewards Are there any other (non-BT) suppliers available to you?
Fixes: 586
@weewards
I would have thought that a single full fibre connection would provide ample bandwidth for both generations.
Offer to contribute to the cost and upgrade your son in laws full fibre to FF900 if necessary. If you really want to separate the 2 generations , then install an ethernet cable from his router to where you want your router. You need a little bit of network expertise but doing that should be able to provide 2 largely separate wireless and wired networks sharing the single full fibre connection.
Fixes: 480
Many people associate the closing down of the PSTN telephone system with switching off the copper cable to your property. This is not the case. In terms of ‘switching off copper’, what is happening is that the connection between your FTTC street cabinet and the telephone exchange is being disconnected, the copper from the FTTC cabinet to your property remains active, providing you with a broadband connection.
Providing you are not in a fibre priority area you should be able to convert to SoGEA, be that if you stay with Plusnet you will need to either lose your landline phone or use a third party VoIP provider.
If you are in this fortunate position you should do it without delay. With the roll out of FTTP, exchange areas are being moved to fibre priority status at an increasingly rapid rate.
pvmb
Champion
Fixes: 17
Well no...  Also, it would surely be Openworld that refused this? But why would you need "two full fibre circuits to the same address"?
An interesting question though. With FTTP would it be possible to have two different ISP services at the same address, via the same ONT? (ONT would presumably need to be one with two Ethernet ports).
Fixes: 392
AIUI, Openreach no longer supply multi-port ONTs - read that somewhere recently. As I said above, the only way to get two FF connections - a little expensive - is to keep the BT supplied one,  and see whether an altnet, or someone using say, the Cityfibre network, would install a second full connection.
Fixes: 118
@pvmb
When I had FTTP installed in late 2017 I got a 4 port ONT with a separate battery back up unit. It was technically possible to receive 4 separate feeds but the problem would have been finding ISP's to supply.
OpenReach have recently been trialing 4 port ONT's but I gather they have cancelled the trial due to problems identified.
https://www.ispreview.co.uk/index.php/2026/03/openreach-to-fully-withdraw-multiport-ont-on-uk-fttp-b...
pvmb
Champion
Fixes: 17
It occurs to me that there may be an underlying misunderstanding here, of how the GPON (optical network) works. This misunderstanding could be shared by others: that the fibre (FTTP) link is just a 'Go Faster' version of the existing private line, landline network. It isn't.
A copper landline is a private line to a specific address that connects back to the local cabinet (in the first instance). It is an private, unshared, copper analogue electrical circuit, one to each individual household wall socket.
With FTTP (the GPON) it isn't like that. It's not electrical, it isn't circuit based, it isn't analogue and it isn't there to provide an unshared private line to each household. The fibre is there simply to connect each premise up to the digital optical network (GPON). It isn't 'your private line', it is a sort of incoming broadcast system, rather like DAB or DTV. It is the job of the ONT - each with a unique ID registered to the address where it is installed - to decode the data coming in for your premises. What services are coming out of your ONT Ethernet port is down to what arrangements you have with your ISP.
So you can have (cough!) 'Broadband' with one ISP and a VoIP telephone service with another.
