Mullvad VPN
omnicaritas
Mullvad VPN
I can no longer access this site as it's been blocked by PlusNet. Are all VPNs blocked?
Best,
Tim
16 REPLIES 16
Fixes: 392
Re: Mullvad VPN
Not so far as I'm aware - is it a legitimate site?
omnicaritas
Re: Mullvad VPN
Yes. I've been using it successfully until about 4 weeks ago.
mullvad.net
This is forwarded to block.opendns.com which tells me that the site is blocked due to content filtering.
Fixes: 392
Re: Mullvad VPN
I'm possibly not the best person to answer this, as I'm not on the PN network, but it looks legit enough to me - I can certainly access it.
You really need a PN customer to check this for you.
Fixes: 585
Re: Mullvad VPN
@omnicaritas are you using the OpenDNS DNS servers ?  sounds like its those that are blocking it
Champnet
Fixes: 21
Re: Mullvad VPN
I’m a Plusnet customer and can access the site with it’s bright yellow background….
omnicaritas
Re: Mullvad VPN
I'm not sure. What is the default for plusnet users?
omnicaritas
Re: Mullvad VPN
OK. Thanks for letting me know. I'll contact PlusNet directly.
Fixes: 585
Re: Mullvad VPN
The default is to use Plusnet's DNS servers.
Fixes: 480
Re: Mullvad VPN
Moderator's note:
Thread moved from Broadband to Everything Else
Re: Mullvad VPN
@omnicaritas
It could be Plusnet's server side firewall, which occasionally gets altered (on an account change/upgrade) to "High" (i.e. maximum protection), which unfortunately will block a VPN connection.
To check this,
    login to your Plusnet account using the "Member Centre"
    then use this link to navigate to the "Broadband Firewall"
    If it's not set "Low" already, change the firewall level to "Low", and then reboot your router for the change to occur.
The "Low" setting should allow a VPN to connect from your home network.
If you are running OpenDNS -
    login to your "OpenDNS dashboard"
    click on the orange "SETTINGS" tab, and then in "Select a network" click on your connection,
    then choose "Web Content Filtering"
    scroll down to the bottom of that page and find "Manage individual domains"
    click on the "Always block" button to reveal a drop down list, then select "Never block"
    in the box to the right, enter the domain to NOT be blocked - presumably "mullvad.net"
    then hit the "ADD DOMAIN" button
    wait three minutes, and the domain should be whitelisted and not blocked - assuming that the URL is correct !
Re: Mullvad VPN
@omnicaritas
You can test whether your connection is using OpenDNS by clicking on their checker - welcome.opendns.com
If your home network is using OpenDNS (as mine is), the above link will show -
If you're not using OpenDNS then it'll show a cross -
RealAleMadrid
Fixes: 68
Re: Mullvad VPN
@Anonymous  You've jumped in here with a number of posts, firstly I don't believe it is anything to do with the Plusnet firewall. From what I can gather the OP is just trying to access the Mullvad website not connecting via a VPN. Not sure why you think the firewall can change to high either, not seen any evidence of this.
Re: Mullvad VPN
@RealAleMadrid wrote:
... I don't believe it is anything to do with the Plusnet firewall. From what I can gather the OP is just trying to access the Mullvad website not connecting via a VPN
From the original post Message #1 -
It's happened to me TWICE, coincident with upgrading my Plusnet account.  It has also randomly gone to "Off" on several occasions !
In the past others complaining of being unable to connect via VPN have fixed the issue by switching the firewall to "Low" from "High" having previously being unaware that the "Broadband Firewall" existed - so obviously THEY hadn't altered the setting in their "Member Centre" console.
RealAleMadrid
Fixes: 68
Re: Mullvad VPN
@Anonymous  On a recent thread about a VPN not working a forum member said their firewall settings did not change after many upgrades and re-contracts, you obviously have had a different experience.
I have always set the firewall off as it's a legacy service that is no longer needed, perhaps you should do the same.
I would say that "I can no longer access this site" means the website rather than using their VPN service, you seem to have interpreted it in a different way.
