Moving to Full Fibre, but living in a listed building has thrown a spanner into the works
- Everything else
- Moving to Full Fibre, but living in a listed build...
- « Previous
- 1
- 2
- Next »
Re: Moving to Full Fibre, but living in a listed building has thrown a spanner into the works
2 weeks ago
Does the conduit not have an "up to x diameter" so basically one size fits all notmal cabling.
No it doesn't, all it quotes is the external dimensions. i.e. 16mm wide x 10mm height half round. So I am thinking 1mm wall thickness on the height will leave me with a 8mm cable space.
2 weeks ago
I don't see any problems any problems with the cable. Given the status of the building I would have any documentation showing the allowed route ready for the engineer in case they want to see it and then, when you've agreed the route put the trunking in while they do other work.
When's the install due?
2 weeks ago
Mid May. Thought I would give myself plenty of time, Plus Easter and the Bank holiday get in the way of things as well.
Just had a neighbour round who has been told to disguise a cable running up 4ft of his wall as it looks unsightly. At least they didn't tell him to remove it.
a week ago
This is an increasing problem with regard to constipation area committees and so on, digging their heels in and trying everything to prevent FTTP installs.
A slight change in the wording you use for such installs can work wonders, instead of full fibre internet install from open reach, referring to it as a new phone line, or replacing/renewing the phone line with some work by British Telecom (formerly known as the GPO) can help. If they ask for more details you can also add a small discreet junction box will need to be added
In my experience, a lot of these committees who rule Conservation areas are usually made up of older people who see the internet as a frivolity and certainly dont see the need for faster internet when their sub 2mb ADSL connection does the job for them just fine.
Gather some evidence, look round your conservation area and see what other buildings/properties have the grey openreach boxes and ( from a public area ie pavement) take photos to use in evidence
But refer to it as needing to replace the phone line - which technically it is as you can use it for Voip phone services as if you are in a fibre priority area thats the only option for voice calls
Friday
For constipation you need a GP, not the former GPO.😀 (Predictive texting has a lot to answer for.)
- « Previous
- 1
- 2
- Next »
- Everything else
