Moving 850GB from PC to NAS drive
zpeterk
What is the best way to move files from PC hdd to a NAS drive, copy over network, USB hdd backup and restore or something else?
4 REPLIES 4
Fixes: 400
Re: Moving 850GB from PC to NAS drive
@zpeterk
Most defininitely copy over the network PROVIDING both NAS and PC are connected to the router via Ethernet cables.
Alternatively a possibly even faster way is to remove one of your NAS drives and install it in your PC using the fastest SATA port in your computer. Do an internal transfer to this disk then put it into your NAS and rebuild the array.
Fixes: 356
and that both have Gigagbit connections to the router/switch
Fixes: 400
@MisterW
Very true! I'd forgotten that people still use obsolete junk like the Hub Zero.
zpeterk
Everything is connected by cables to a 1GB switch
