Mod_rewrite, .htaccess and cakephp
- Everything else
- Mod_rewrite, .htaccess and cakephp
25-08-2007 7:20 PM
I'm trying to get cakephp working. This relies heavily on url rewriting using mod_rewrite commands in .htaccess. I read somewhere that Plusnet's cgi implementation of php means that .htaccess rewrite rules won't work. Is this correct?
I have a similar problem with search-friendly urls on my mambo website, but maybe that's because I haven't got the rewrite rule correct.
Tony
Tony
Message 1 of 4
(3,067 Views)
3 REPLIES 3
Re: Mod_rewrite, .htaccess and cakephp
25-08-2007 10:35 PM
mod_rewrite works fine - just do a search for it to find people using it.
What you can't do is protect any php files as php is run in cgi mode rather than as an Apache module.
Message 2 of 4
(755 Views)
02-09-2007 3:47 PM
Well mod_rewrite may be present, but it doesn't seem to work as it should. I installed cakephp on apache on my own PC and redirection works straight out of the box. Do I need to put some other directive in my .htaccess files?
Anyone else using .htaccess rewrite rules?
Tony
Tony
Message 3 of 4
(755 Views)
02-09-2007 8:36 PM
Posting what you have in your .htaccess would help?
Message 4 of 4
(755 Views)
- Everything else
