Missing links on my website
- Everything else
- Re: Missing links on my website
29-04-2009 8:47 PM
I have recently upgraded to Internet Explorer 8. I'm running Vista Home Edition. Now I can gain access to my index page but the buttons liking to my other pages appear as rectangles with a small red cross in them and nothing happens if i click on them. I get the gold bar at the top say i need to install active x control. when i try to install this it says windows or IE 8 denies this as publisher can't be veryfied, and gives the name of my website. www.barnsley2day.co.uk ; Is it refering to the publisher of active x control or to my website, if so how can i verify the authenticity of my website? Or has anyone any idea's as to how I can cure this. Such as settings in internet options etc: I might add that everything did work fine with IE 7 Any help much apreciated.
Percy.
Percy.
Message 1 of 5
(1,341 Views)
4 REPLIES 4
29-04-2009 8:50 PM
Welcome to the forums
Are these the buttons on the left hand side?
They work in IE8 here OK.
Message 2 of 5
(447 Views)
29-04-2009 9:23 PM
Yes Adie, they are the buttons on the left side. I have also just re-installed windows XP on my desktop with IE 7 and i get the same non functional result from there too. The Vista OS is on my laptop. With things as they are at the moment i can't install active x control on either computer..
Percy.
Percy.
Message 3 of 5
(447 Views)
29-04-2009 11:47 PM
Those buttons are all Java applets. Have you got Java installed and given permission to run? Have you tried repairing/reinstalling Java?
Message 4 of 5
(447 Views)
30-04-2009 12:22 AM
Thank you Nigel, you're a top.... I re-installed java and everything is fine now..
All the best Percy.
All the best Percy.
Message 5 of 5
(447 Views)
- Everything else
