Mapping a domain name to SquareSpace - Help please!!
longdraws
I have recently built a website in Squarespace and need to 'map my domain', which is hosted by PN. I curretly have my old site up and hosted by PN on the domain elizabethbee.co.uk
Suarespace says that I have to map the domain, so I have create a new DNS record for elizabethbee.co.uk in PN:
Current DNS records for elizabethbee.co.uk
Left field Type Pri Right field
www CNAME ext.squarespace.com.
Is this correct? Do I have to do anything else or just wait?? I have not created an A record...do I need to do that too?
Please help!! This is above my understanding!
10 REPLIES 10
longdraws
Trying to configure CNAME for Squarespace
What do I have to do...I have set up a new DNS:
Please can someone help me...this is way beyond my understanding and I need to get it working soon. Last time I asked Plus.net a question in the Member Centre, they took nearly a week to reply!
pwatson
Re: Mapping a domain name to SquareSpace - Help please!!
You should only need the CNAME record, but note that it can take 24-48 hours for the change to take affect.
Oldjim
Fixes: 63
Two topics merged
pwatson
All looks OK, and the website works...
Trying "www.elizabethbee.co.uk"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 29445
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; QUESTION SECTION:
;www.elizabethbee.co.uk. IN ANY
;; ANSWER SECTION:
www.elizabethbee.co.uk. 14400 IN CNAME ext.squarespace.com.
;; AUTHORITY SECTION:
elizabethbee.co.uk. 14400 IN NS ns2.force9.net.
elizabethbee.co.uk. 14400 IN NS ns1.force9.net.
;; ADDITIONAL SECTION:
ns1.force9.net. 74084 IN A 195.166.128.16
ns2.force9.net. 74084 IN A 195.166.128.17
longdraws
Thanks, I guess I'll just wait a while to see if it changes and points to my new website. Thanks for checking for me 🙂 Grin
longdraws
Do I need to create an A type DNS record before a CNAME can work?
PN are being absolutely awful and I am getting nowhere with the lady on the phone...she has even less knowledge than me!  Embarrassed Can you tell me if I need to create an A type record for my domain name to be pointed at another company? I have created the CNAME?
I have done the nslookup thing and it says it is going to Square space but that it is timing out...is this normal? I cant see anything yet after 24 hours...still the old website.
Anyone clarify this for me?
James
Re: Do I need to create an A type DNS record before a CNAME can work?
Do you mean the hosting is with a different company?
Should that not just be a case of changing the DNS records? Sorry - I'm a bit limited in my knowledge of domains, but I thought that you would just need to change the nameservers.
pwatson
[Reported to mod to merge topics - again!]
You don't need to change the A record and, as I said yesterday, your CNAME change has pointed www.elizabethbee.co.uk to your external host.
Try flushing your browser cache?
This is what I see - Is this wrong?
longdraws
Hi guys, thanks for the replies. You do seem to be seeing the correct website from your screen shot, but I am not. I have cleared the browser history/ cache and I still see the old website. Is it possible we can see both?
longdraws
YAY!! Its working at last  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Thanks for all your help!!
