Mapping a domain name to SquareSpace - Help please!!
- Everything else
- Re: Do I need to create an A type DNS record befor...
03-12-2013 4:11 PM
I have recently built a website in Squarespace and need to 'map my domain', which is hosted by PN. I curretly have my old site up and hosted by PN on the domain elizabethbee.co.uk
Suarespace says that I have to map the domain, so I have create a new DNS record for elizabethbee.co.uk in PN:
Current DNS records for elizabethbee.co.uk
Left field Type Pri Right field
www CNAME ext.squarespace.com.
Is this correct? Do I have to do anything else or just wait?? I have not created an A record...do I need to do that too?
Please help!! This is above my understanding!
Trying to configure CNAME for Squarespace
03-12-2013 8:48 PM
Please can someone help me...this is way beyond my understanding and I need to get it working soon. Last time I asked Plus.net a question in the Member Centre, they took nearly a week to reply!
Re: Mapping a domain name to SquareSpace - Help please!!
03-12-2013 9:07 PM
You should only need the CNAME record, but note that it can take 24-48 hours for the change to take affect.
03-12-2013 9:10 PM
03-12-2013 9:12 PM
Trying "www.elizabethbee.co.uk"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 29445
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; QUESTION SECTION:
;www.elizabethbee.co.uk. IN ANY
;; ANSWER SECTION:
www.elizabethbee.co.uk. 14400 IN CNAME ext.squarespace.com.
;; AUTHORITY SECTION:
elizabethbee.co.uk. 14400 IN NS ns2.force9.net.
elizabethbee.co.uk. 14400 IN NS ns1.force9.net.
;; ADDITIONAL SECTION:
ns1.force9.net. 74084 IN A 195.166.128.16
ns2.force9.net. 74084 IN A 195.166.128.17
04-12-2013 8:17 AM
Do I need to create an A type DNS record before a CNAME can work?
04-12-2013 1:09 PM
I have done the nslookup thing and it says it is going to Square space but that it is timing out...is this normal? I cant see anything yet after 24 hours...still the old website.
Anyone clarify this for me?
Re: Do I need to create an A type DNS record before a CNAME can work?
04-12-2013 1:24 PM
Should that not just be a case of changing the DNS records? Sorry - I'm a bit limited in my knowledge of domains, but I thought that you would just need to change the nameservers.
04-12-2013 1:25 PM
You don't need to change the A record and, as I said yesterday, your CNAME change has pointed www.elizabethbee.co.uk to your external host.
Try flushing your browser cache?
This is what I see - Is this wrong?
04-12-2013 2:07 PM
04-12-2013 2:09 PM
- Everything else
