Malware on my webspace
- Everything else
- Re: Malware on my webspace
14-06-2009 11:20 PM
When I looked at my webspace today I got this message
It's says this website contains elements of molo.tw malmare.
When I looked on ftp I found an index.html had been added with about 10 folders with random jpegs in them.
I've done a malware search on my machine and I'm fairly sure I'm clean.
I've no idea where these files have come from and some of it I can't seem to delete.
I tell it to delete, the file list refreshes and it's still there. I'm using FileZilla to access it.
Message 1 of 6
(1,599 Views)
5 REPLIES 5
15-06-2009 7:07 AM
Are the file permissions set so that you can delete them?
Message 2 of 6
(433 Views)
15-06-2009 7:44 PM
It's set to read, write and execute. Is there anything else I need to do?
Message 3 of 6
(433 Views)
16-06-2009 2:39 AM
Make sure the folder permissions allow writing so you can delete their contents.
David
Message 4 of 6
(433 Views)
16-06-2009 4:37 PM
Also make sure whatever you are using to delete stuff can see hidden files, such as .htaccess. If you haven't deleted them, FTP won't allow you to delete the directory (unless the FTP client is particularly clever).
Message 5 of 6
(433 Views)
16-06-2009 9:42 PM
It was hidden .htaccess files that were preventing me from deleting the folders.
All deleted now. Thanks.
Message 6 of 6
(433 Views)
- Everything else
