Mailform Script NOT working - help!
- Everything else
- Mailform Script NOT working - help!
- « Previous
- 1
- 2
- Next »
Re: Mailform Script NOT working - help!
28-05-2008 2:46 AM
Quote from: emmajane So how do you make something appear in the "from" field so it doesnt come back saying unknown sender?
You could try adding another hidden field to your form
<input type=hidden name="email" value="customer@emma-jane.com">
Message 16 of 17
(178 Views)
28-05-2008 2:54 PM
The trade form just gives you a list of pictures to download and seems to work ok. As its the same as the other form it will be caught as SPAM and the solution is the same as I suggested before. There isnt much point to it as it just sends a name that means nothing I used fred
We need clarification of the problem
Message 17 of 17
(178 Views)
- « Previous
- 1
- 2
- Next »
- Everything else
