Madasafish / Freenetname Domain renewal
PJGarvey
Can somebody tell me how to renew my Madasafish domain. I have done this previously for the past two years by ringing up and it was sorted the same day. Now when I phone it seems that no one can help.
Regards Peter
17 REPLIES 17
Fixes: 460
Re: Madasafish / Freenetname Domain renewal
Moderator's Note
This topic has been moved from Tech Help to Everything Else
rockyd
Hello PJGarvey,
Iam having similar issues with my old freenetname/madasafish domain name which is expiring at the end of January 2023!
I raised a call with support om the 20th December to extend the registration on the domain - there has been no plusnet updates to the ticket.
I called support again yesterday, after getting transferred to 3 different areas I was advised that the domain would be extended in the next 72 hours - didnt get the assurance I needed. As this domain is used for my email address - concerned!
Currently looking at options to secure the domain if plusnet dont, An option I dont really want to go down,
PJGarvey
Thanks for your reply. What number did you call for support?
rockyd
Standard support number on 0800 432 0200.
rockyd
Looking on some other threads on this topic @Gandalf appears to have helped users with this issue. reaching out for help before the domain expires, appreciate any help with this matter,
PJGarvey
I'm new to forums. How do I contact @Gandalf ?
Fixes: 531
@PJGarvey You just did!
By tagging someone in a post , they will get a notification, just like you have...
Fixes: 1,642
@PJGarvey and @rockyd - I've raised internal tickets to NetOps for you. I'll let you know when they get back to me which should be within the next 3 working days.
rockyd
Thanks @Gandalf . Looking forward to getting this resolved.
PJGarvey
Thank you for your help.
Fixes: 1,642
@PJGarvey - Your domain's been renewed until 1st December 2023.
@rockyd - The task for your domain hasn't been picked up yet but should be next week if not today.
PJGarvey
Thank you so much. All working again now.
Really appreciate the help.
Thanks again  @PJGarvey
Fixes: 1,642
No problem at all, let us know if there's anything else you need help with and have a good weekend Smiley
rockyd
@Gandalf Just checked and my domain still to be renewed. I'll check later today.
