Madasafish Domain
kwestgate
Madasafish Domain
Hi we have a domain name that was registered with madasafish but we havent used it.  Id like to pick it back up but it's so old we dont have the original email account that it was registered to so are hitting a wall with logging in.  Can you help? How do we go about transferring it to another company? Its due for renewal in another year and Id like to get a website up and running.  Thanks
1 REPLY 1
Fixes: 1,662
Re: Madasafish Domain
Do you know the password for the domain? If so try logging in Here using that and your full domain name. Send me a private message with the domain if that works and I'll create a ticket on the account to begin the transfer.
If that doesn't work and you don't know the account username or password, then you could ask Nominet to transfer the domain. There's some instructions here https://www.nominet.uk/transferring-your-domain-name/
