Macafee end of subscription alert
sheffpete
Hi, I'm getting a windows security alert that my Macafee subscription ends in a few days, how windows would know that i'm not sure, and I thought Macafee was an included product with fibre extra ?
Just wondered if anyone else had come across this ?
cheers.
7 REPLIES 7
Fixes: 1,483
Re: Macafee end of subscription alert
Moderators Note
This topic has been moved from Fibre to Everything Else
Fixes: 1,483
McAfee can trigger alerts through the windows messaging service, nothing to be alarmed at.
Did you install it through your PN account here https://www.plus.net/AddOns.html?
Fixes: 1,600
Hi @sheffpete
Our Plusnet Protect product (powered by McAfee) works on a 30 day basis that automatically renews on your bill date.
I've checked your account and I can't see any issues with it. Can you let me know if it actually does expire?
sheffpete
Hi, Yes did go via a Plusnet link, not sure if it was that exact one tho ...
sheffpete
OK will let you know if Macafee says its stopped, had this enabled quite some time so lots of 30 day renewals must have happened without any alerts tho ...
sheffpete
well Macafee seems to still be working, no end of service messages and if i open it via the icon it says all is secure ...
Fixes: 1,600
Ah that's good to see @sheffpete it's really odd to see the alerts have only just started coming through to you.
I'd check within Windows notifications & system settings as well as McAfee's settings if there's a way to turn them off.
