Login failure due to : remote host not responding
- Everything else
- Login failure due to : remote host not responding
13-01-2015 4:56 PM
Trying to login using my work laptop via VPN but keep getting 'login failure
remote host not responding' I switched firewall setting to LOW which supports VPN but still
No avail.
No avail.
Message 1 of 3
(909 Views)
2 REPLIES 2
Re: Login failure due to : remote host not responding
13-01-2015 5:00 PM
Have you disconnected from Plusnet and reconnected since you changed the firewall setting? You can do that in the router GUI, no need to restart the router.
David
Message 2 of 3
(306 Views)
13-01-2015 5:01 PM
Trying to login to what and why using a VPN?
Do you mean you're trying to establish a VPN connection to work? If so, what result do you get if you ping or use traceroute to the server you're trying to connect to?
Message 3 of 3
(306 Views)
- Everything else
