Location of Sendmail for CGI scripts?
- Everything else
- Location of Sendmail for CGI scripts?
09-04-2009 2:02 PM
Anyone know the location of the PlusNet server's Sendmail program, so I can use it in a version of FormMail.pl in the CGI-bin folder? Apparently it's normally something like '/usr/lib/sendmail' on other servers?
Message 1 of 2
(793 Views)
1 REPLY 1
Re: Location of Sendmail for CGI scripts?
11-04-2009 9:41 AM
Hi Starfour.
If you login via SSH to the CGI space you can then use the whereis command to locate the path any script or application. On the Plusnet CGI paltform sendmail should be available as follows;
/usr/lib/sendmail
/usr/sbin/sendmail
I hope this helps.
/usr/lib/sendmail
/usr/sbin/sendmail
I hope this helps.
Message 2 of 2
(249 Views)
- Everything else
