Live streaming
- Everything else
- Live streaming
Live streaming
07-07-2019 12:19 PM
Sorry I don’t know what forum to post this question in, doing a search has only confused me more lol
I’ve recently been having problems with live video streaming. It keeps pausing and reloading., that little circle going round. The audio also can drop out of sync. I have checked buffering as well as I can using advice on the net and it seems ok.
Download and upload speeds look OK if a bit erratic using BTW performance test and good ping latency. I did get a message a couple of times using BTW advanced test saying “The Performance Tester is disabled to support TAP3 for your broadband connection” A foreign language to me so do I need to do anything to put matters right
Non technical assistance would be appreciated, many thanks
Re: Live streaming
08-07-2019 8:56 AM
Hi @arjay
Thanks for getting in touch - I'm sorry that you're experiencing connection issues. I've tested your connection from this side and although there are no errors on your line, the speed is a little lower than I'd expect.
Could you connect your router to the test socket of your premises (as shown here) and try to stream something to a device that is connected to the router via a wired, ethernet connection?
If you could also run a speed test via a wired device and record the results that would be helpful.
Let us know how you get on.
Best wishes
Dave
Re: Live streaming
12-07-2019 2:25 PM
Hi RandallFlagg, Sorry I'm not ignoring you, other things came up but I'll get round to doing what you said asap
Re: Live streaming
12-07-2019 3:00 PM
No worries @arjay.
Just give us a nudge on here when you get a chance to try the checks/tests and we'll pick it up as soon as possible.
Thanks.
Re: Live streaming
14-07-2019 7:02 PM - edited 14-07-2019 7:04 PM
In what context? Netflix?
Generally I get good performance when watching Netflix … however sometimes (yesterday) I see really poor buffering … poor picture quality and a loss of voice sync. Do a short rewind and all is fine until I hit the same part of the video again. I've also seen Netflix hang at 24%, 25% or 99% loading and just hang for ever.
This seems to be a know glitch with Netflix with a number of try this try that mitigations reported around the internet. I found turning the TV off and back on again totally fixed the "buffering" issue. I have also experienced Netflix reporting no internet connectivity when the TV reports that it has a good fast connection.
… if you are not using Netflix here, I will quietly leave back though the door I came in by!
Re: Live streaming
15-07-2019 9:50 AM
It is streaming of a twice weekly public meeting. The server at source is incidentally PN
PC is HP laptop-Intel Core i5 7200U
All HP and Intel drivers up to date. Windows update current
Running on dual wireless 2.4/5Ghz. Have changed to 5Ghz only with no significant difference
Router connected to master socket, pc connection to router wired
BTW speed tests
Router status wife speed 100mbps
Upload 19.92 Mbps
Download 4.18 Mbps
Ping 33
Diagnostic test 19.92/4.1
Wireless test
Router status WI-FI speed 433.3mbps
Upload 20.24
Download 4.17
Ping 42
Diagnostic test
Test error-The Performance Tester is disabled to support TAP3 for your broadband connection.
I have had no problems with streaming previously, this has only started over the last month or so
Re: Live streaming
15-07-2019 1:50 PM
Hi @arjay,
Thanks for getting back to us, I appreciate you taking the time to send us this information.
Please can you confirm that you have connected your router to the test socket that is located below the faceplate of the master socket. The faceplate needs to be removed as per the instructions sent earlier.
Once this is done, please run the speedtest again.
Apologies if you have already removed the faceplate and run the test. If this is the case, please do get back to us.
Thanks - LF
Re: Live streaming
15-07-2019 2:25 PM
Hi LordFoul
Yes, the faceplate pulls off, not a screwed on job, and the socket is under it, I take it I have to connect the splitter not just the router
Re: Live streaming
15-07-2019 2:35 PM
Hi @arjay,
Thanks for that info. Yes the ADSL microfilter needs to be connected first and the router to the filter.
Thanks - LF
Re: Live streaming
15-07-2019 3:16 PM
At last I did something right
Re: Live streaming
15-07-2019 3:21 PM
Re: Live streaming
15-07-2019 3:33 PM
I connected the ADSL microfilter first, that's why I was surprised I got it right first time
Re: Live streaming
15-07-2019 3:57 PM
Re: Live streaming
15-07-2019 4:24 PM
I didn’t run any tests without it connected.
In my rummaging around, I found under network adaptors- Intel dual band wireless – AC 3168, properties, allow the computer to turn off this device to save power was ticked, would this make any difference
Re: Live streaming
15-07-2019 5:18 PM
Hi arjay,
That would be for the laptop only but yes if the computer was conserving power and the network adaptor was the only means of access to the Internet then if the adaptor was turned off to reserve power then it follows that you would not be able to go online. I'd have this switched on to see whether there's any difference. If you also have an Ethernet port however then you can still go online if it's hard wired.
Is this the only adaptor installed? Do you have issues with other devices at all or is it just the laptop?
Thanks - LF
