Linking non PN webspace to PN domain
- Everything else
- Re: Linking non PN webspace to PN domain
17-01-2008 8:55 PM
I have a site on Fasthosts.com and the domain is registered with force9.
Fasthosts don't accept uk.com domains so could I point the domain at my site on fasthosts.
I currently use a redirect page...not very satisfactory at all.
Will I see www.mysite.uk.com in the Browser address box or xxx.fasthosts.com
Message 1 of 4
(1,303 Views)
3 REPLIES 3
17-01-2008 10:41 PM
PlusNets domain system does not allow setting up A records to IP addresses outside their address range so you can't point a PN hosted domain elsewhere.
You should really transfer out the domain from plusnet anyway as their renewal charges are very high. Move it to say daily.co.uk which I have just started using as 1and1 (my normal registrar) do not support eu.* domains, and Daily's control panel looks very comprehensive. There is also no charge to transfer a domain to them. From there you can point the domain anywhere you like.
Message 2 of 4
(462 Views)
17-01-2008 10:57 PM
Thanks very much for the info Peter.
I will look at moving the domain elsewhere.
It's a pity PN don't support ASP as I would then host the site locally.
Thanks again.
Thanks again.
Message 3 of 4
(462 Views)
25-01-2008 5:07 PM
Quote from: Peter PlusNets domain system does not allow setting up A records to IP addresses outside their address range so you can't point a PN hosted domain elsewhere.
The domain system does indeed allow this (using A or CNAME records). What you can't do is point an externally hosted domains onto our hosting servers.
If your site is sitting on a shared IP (you can check by browsing the IP address of your site and seeing what it comes up with) you'll need the server configuring to accept requests for the hostname you are going to be using.
If you have your own IP address and you can view your site using it, chances are it will work with no modification required on the Fasthosts.com side of things.
HTH.
Message 4 of 4
(462 Views)
- Everything else
