Kodi not working
- Everything else
- Re: Kodi not working
Kodi not working
18-09-2020 4:23 PM
Having only fairly recently moved from Bt to Plusnet I find Kodi is now not working?
Does Plusnet block kodi?
When using a movie search in Kodi its only finding about 5 sources each time and then when you click on a working source it will not play.
18-09-2020 5:46 PM
Plusnet don’t usually block anything directly.
18-09-2020 7:43 PM
Was using Exodus redux but just tried venom and its doing the same things..
finding only about 5 sources for every search, usually plenty of sources, and when you find a source that looks like it will work it shows the little turning circle for a second then stops, like the source is blocked.
23-09-2020 7:55 PM
