Kodi not working
mort58
Kodi not working
Having only fairly recently moved from Bt to Plusnet I find Kodi is now not working?
Does Plusnet block kodi?
When using a movie search in Kodi its only finding about 5 sources each time and then when you click on a working source it will not play.
3 REPLIES 3
RPMozley
Fixes: 9
Re: Kodi not working
What add on is that you are trying to use?
Plusnet don’t usually block anything directly.
That's RPM to you!!
mort58
Was using Exodus redux but just tried venom and its doing the same things..
finding only about 5 sources for every search, usually plenty of sources, and when you find a source that looks like it will work it shows the little turning circle for a second then stops, like the source is blocked.
RPMozley
Fixes: 9
Difficult to tell with “unsupported” add-ons why links not working. Send me a pm with the sources you are looking at, will try to check things out myself if any difference here.
That's RPM to you!!
