JoomlaWorks' Simple RSS Feed Reader
mikiec
I've been trying to get this module working in my Joomla install on CCGI, but it doesn't display any feeds.  Has anyone else managed to get this working?
The instruction say "In order for the module to work properly, your server must have the following PHP modules enabled: cURL, iconv, PCRE, Zlib. Don't worry, though, cause most servers have these PHP modules enabled by default. If not, then contact your hosting company to enable them."
I've run phpinfo and it does appear that these are installed and enabled.
I've tried loads of different RSS feeds, but none of them show.  I've extended the time-out for reading the feeds, but this just makes the page pause for longer before failing to show the feeds.
Any ideas?
