Joomla rewite issues
- Everything else
- Joomla rewite issues
25-03-2008 9:48 AM
Hi - I have a joomla site up and running ok, but I am having trouble getting my SEF to work. I have checked with plusnet support and the mod_rewrite is enabled. I suspect the issue is the correct setting of my rewriteBase. If my site is ccgi.neilstamps.plus.com/WWR - then surely my rewrite base should be /WWR/ ?
Any help would be appreciated.
Message 1 of 2
(837 Views)
1 REPLY 1
Re: Joomla rewite issues
03-04-2008 3:30 PM
Hi - I have just overcome a similar SEF issue in a new Joomla 1.5 installation - make sure that in the Joomla configuration.php file that you have a relevant entry in the "$live_site" line - in your case it would probably be `http://ccgi.neilstamps.plus.com/WWR` . I tried this after noticing an obscure comment in one of the Joomla forums - and hey presto it all subsequently worked.
If this fails there are some third-party extensions for Joomla which mange SEF which are supposed to be much better than the Joomla one - have a look at http://tinyurl.com/ys2nlb for instance.
HTH,
Stuart
HTH,
Stuart
Message 2 of 2
(174 Views)
