Joomla-based site give server ( 500 ) errors since earlier today
PhilC
works fine on php5.2 / apache2 here so doubt that it's an upgrade issue. mediawiki site in same domain is fine and database is fine.
9 REPLIES 9
bobpullen
Fixes: 289
Re: Joomla-based site give server ( 500 ) errors since earlier today
Could it be a problem with .htaccess as per the thread here here?
rekabuk
I get this error too. Although I can FTP to my site from home, I don't seem to be able to FTP from work, even on our "open" network!
I did try playing with the .htaccess last night with no luck., I also uploaded a simple test.php file to the root and could not access that either???!!!
Bit fed fed-up as I moved my Joomla site from the PAYH server cos of all the hassle and now I'm here, stuck again!
Andrew 😞
gandb
My Joomla site http://www.gtsagedev.co.uk is now up and working again.  I had to amend .htaccess to comment out 2 lines:
#Options +FollowSymLinks
#RewriteRule (.*) gtsagedev/index.php
No problems with permissions
Only problem now is with sending mail from the contacts page. The Joomla Mail settings in Global Configuration are
Mailer PHP Mail function
Mail from (my plus.com)
From Name (my name)
Sendmail Path /usr/sbin/sendmail
SMTP Authentication No
SMTP Security
SMTP Port 25
SMTP Username (blank)
SMTP Password (blank)
SMTP Host localhost
But no emails are being sent.  Will experiment and report back!
bobpullen
Fixes: 289
Regarding the php mail () stuff, have a look at my post here.
rekabuk
Thanks Gabe,
I'll try when I get home because although I can FTP to the PAYH and HTTP servers from work, I can't access the CCGI one 😞
Andrew
bobpullen
Fixes: 289
You'll need to be connected to our netwok in order to access the CGI platform.
rekabuk
Gabe,
Quote from: Gabe
I couldn't find the second line you mentioned, but removing
has fixed the problem, now I need to hack through the .htaccess again to hide the joomla install directory again, I know there is plenty of help out there but it takes me ages to get it working...
Bob
Quote from: Bob
I didn't quite understand this comment, was it for me? Of course I'll need to be connected to your network????Huh
Andrew
Gabe
Quote from: rekabuk
Gabe,
That's not me. Thanks gandb  Smiley
The rewrite <a href="http://community.plus.net/forum/index.php/topic,84267.16.html">here</a> might help.
Gabe
bobpullen
Fixes: 289
Quote from: rekabuk
It was a reply to your post here. Some people don't realise that they'll not be able to FTP to the CGI servers from outside of the Plusnet network.
