Joomla anyone?
- Everything else
- Re: Joomla anyone?
Joomla anyone?
11-02-2009 9:12 PM
Hi
I'd like to update the web site I'm responsible for ( http://www.chelmsfordsongsters.org.uk) and I heard someone talking about Joomla. Does anyone know about it or use it? Is it any good? Is it easy? can just upload to my PN space as I do at the moment?
Message 1 of 6
(1,662 Views)
5 REPLIES 5
Re: Joomla anyone?
11-02-2009 9:45 PM
Hi John
http://www.joomla.org/ might help you out.
I doubt very much though you will be able to use it if you are hosting the site on your webspace because it is a content managemrnt system and would probably need full access to the server which obviously with webspace on a shared server you don't have
However I'm not a web designer so don't know for sure.
Looks an interesting site and it looks like you've done a cracking job already.
All the best
All the best
Message 2 of 6
(531 Views)
Re: Joomla anyone?
11-02-2009 11:57 PM
Thanks Techguy
I wondered maybe if I activated SQL and loaded the files into that space, it would let me set up the site.
I suppose I could set up it up on my own computer to try it out, but I don't think I want to set my desktop up as a server (it sounds a bit scary to be honest :-[)
I've never done any of this type of programming before, so it's very new to me.
Message 3 of 6
(531 Views)
Re: Joomla anyone?
12-02-2009 9:06 AM
IIRC, I've set it up on the Plunet CGI space before, although if the newer versions require PHP5 then you might be out of luck. You might want to consider moving your site to our new hosting platform.
Message 4 of 6
(531 Views)
Re: Joomla anyone?
13-02-2009 9:38 AM
Please can you tell me how to get rid of this error message when going to the back end of my Joomla web site http://www.allanassociates.net/administrator - The front end appears ok at www.allanasociates.net
CCGI Error: Execution of this script not permitted
Execution of (administrator/index.php) is not permitted for the following reason:
Script is not executable. Issue 'chmod 755 filename'
Server Data:
Server Administrator/Contact: support@plus.net
Server Name: www.allanassociates.net
Server Port: 80
Server Protocol: HTTP/1.1
Virtual Host: www.allanassociates.net
Request Data:
User Agent/Browser: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648)
Request Method: GET
Remote Address:
Remote Port: 30704
Server Data:
Server Port: 80
Request Data:
Request Method: GET
Remote Address:
Remote Port: 30704
Message 5 of 6
(531 Views)
Re: Joomla anyone?
13-02-2009 10:05 AM
This might help.
Message 6 of 6
(531 Views)
