Joomla Setup question
- Everything else
- Joomla Setup question
22-11-2010 10:16 PM
Any pointers as to what I need to do now as I'm not sure what has changed (or I've forgotten :-[)
Thanks for any advice and guides.
Re: Joomla Setup question
23-11-2010 1:38 AM
You can unzip the file on the server using one of the following bash scripts:
Quote from: Gabe At simplest, create a .cgi file such as: #!/bin/bash
echo "Content-type: text/plain"
echo
unzip joomla.zip
whatever.cgi, placed in the same folder as joomla.zip. Set the cgi script's permissions 0700, and run it from your browser. Or, for .tar.gz:#!/bin/bash
echo
tar -xvvzf joomla.tar.gz
Gabe
23-11-2010 10:58 PM
It was before March, so that explains why I've had the problems now.
Also helped when I realised that I needed to rename the joomla installation download to joomla.zip
Now I've got it unzipped I'm getting the following error when I browse to the site to try and run the installation
Server error!
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: index.php
If you think this is a server error, please contact the webmaster.
Error 500
Any more ideas on what I'm now not doing? Have done chmod 755 for the folder that it is in as this is what I have previously used.
24-11-2010 2:34 AM
25-11-2010 12:09 AM
I've got a bit lost after that and have tried permissions of 710 and 750 without success and also applying 640 to the htaccess.txt file.
Looking at Gabe's post about suEXEC, it would appear this may be the approach needed to modify the joomla installer to allow for the ~username
I've pasted the htaccess.txt below. Do I need to change it in the SEF section from RewriteCond %{REQUEST_URI} !^/index.php to RewriteCond %{REQUEST_URI} !^/~username/index.php?
# @version $Id: htaccess.txt 14401 2010-01-26 14:10:00Z louis $
# @package Joomla
# @copyright Copyright (C) 2005 - 2010 Open Source Matters. All rights reserved.
# @license http://www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations. It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that dissallows changing it in
# your .htaccess file. If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's. If they work,
# it has been set by your server administrator and you do not need it set here.
## Can be commented out if causes errors, see notes above.
# mod_rewrite in use
RewriteEngine On
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
## Deny access to extension xml files (uncomment out to activate)
#<Files ~ "\.xml$">
#Order allow,deny
#Deny from all
#Satisfy all
#</Files>
## End of deny access to extension xml files
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root)
# RewriteBase /
########## Begin - Joomla! core SEF Section
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
RewriteRule (.*) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
########## End - Joomla! core SEF Section
Thanks again for your help.
25-11-2010 8:10 PM
What does need changing is to comment out (add # in front of 'Options' on) the
Options +FollowSymLinks line
and you might need to activate (remove the # from)
#RewriteBase /
As far as the /~username problem is concerned do you mean your full domain name appears twice? The posted text isn't clear in that respect due to URL mangling. You could add [nobbc] ... [/nobbc] tags round the text to stop it being hot-linked and abbreviated..
27-11-2010 9:51 PM
Yes, I do mean the domain name appears twice which it does not do for the older joomla sites I've been running.
http://ccgi.username.plus.com/~username/sitename/ is coming up rather than http://ccgi.username.plus.com/sitename/ as I still get for those sites.
PS Not sure if I've used [nobbc] correctly. I wasn't sure if this was supposed to show round my url
28-11-2010 12:15 PM
Sorry, memory snafu about the content of %{REQUEST_URI}. It *does* contain /~username within .htaccess files, but *doesn't* in PHP.
So that needs to be allowed for. I think your original question is correct, the first %{REQUEST_URI} needs to be
but also the other changes are needed.
28-11-2010 8:48 PM
I've been looking at http://community.plus.net/forum/index.php/topic,84267.16.html where there seems to be quite a few people with joomla problems, but these seem to have been resolved with the # Options +FollowSymLinks change to htaccess.
I've removed the folder and recreated it and reinstalled joomla to try a clean install again, but I'm still getting the same error. I'm using FileZilla to view the folders and change permissions etc but I've not had any problems with it in the past.
Really confusing me and also giving me some problems as I need to build and test a new joomla site before I let the end user loose on it having moved it to a host they will be buying and paying for once I can demonstrate the site.
30-11-2010 10:06 PM
I've also applied the other suggestions you provided as well as pointing RewriteRule (.*) to the /~username/sitename/index.php
Apart from the potential security issue, I'm not sure what actually was needed to resolve this. Any further ideas or suggestions and should I be looking at changing file permissions now that I've got joomla installed?
30-11-2010 11:40 PM
Are any of the files you had to chmod 0750 executable, but not of type .php, .pl or .cgi? Otherwise chmod 0640 should have been sufficient; did you try that? 0640 makes the files readable by Apache. 0750 on directories is sometimes needed, when Apache needs to list directory contents.
I think 0750 on directories and 0640 on files is reasonably safe on new ccgi, but obviously there is slight additional risk.
05-12-2010 10:37 PM
I'd take a guess that this has something to do with the problem I had, but is there any particular reason why this is happening and suggested chmod settings to deal with it?
06-12-2010 1:29 PM
I created the subfolder using FileZilla. Permissions on that came up as 0750. I uploaded the Joomla 1.5.22 zip file to that folder and unzipped it using the cgi script mentioned in an earlier reply. Then uploaded the cgi setperms script to my subfolder and ran it. This set all directory permissions (including those for the containing subfolder) to 0710, and php, pl and cgi file permissions to 0700. Other file permissions were left as they were (0644).
I ran the Joomla install script in my browser entered the required information and it installed OK. I left FTP configuration at the default 'no' to the enable option and entered nothing in the boxes (it isn't needed).
My impression is that you are installing Joomla at the top level. The permissions on that directory (set by Plusnet when your ccgi space was created) should be 01710. You shouldn't change those and the setperms script has a test to avoid doing that.
When working with FileZilla you should be logged in so that the owner (first number/triple) permissions apply which I would expect to be '7' or 'rwx' on all directories and subdirectories. 'Unable to list contents' suggests to me that the permission on your directories are wrong.
In case the problem starts from the top level you can check that using the following script
[code=toplevelperms.cgi script]
#!/bin/bash
echo
ls -l -d .[/code]
FTP it to your top level, set its permissions to 0700 and run it in your browser. The output should be similar to
[code=results]
drwx--x--T 13 username cgiusers 16384 Dec 6 12:09 .[/code]
Hope this sheds some light on the problem you are experiencing.
07-12-2010 3:39 PM
Seems to be the permissions on the index.php and install.php files that were giving me the problem. Once changed to 700 as you and gabe suggested it ran fine.
Hope this will help others get joomla installed and running again.
Thanks for your help and advice. I would not have been able to follow the previous discussions without you pointing me in the right direction.
Edit - got setperms.cgi to work after changing its permissions to 700. Missed that first time...
