Joomla Install Session Save Path error
- Everything else
- Joomla Install Session Save Path error
27-10-2010 6:01 PM
I have got several Joomla websites running (three in the same PAYH space but for reasons beyond my comprehension I cannot get a new one to install. I can get the install package to open and select the language but on clicking "next" I get this error.
Any clues out there it is driving me nuts now
BTW Cookies are enabled.
Quote An error has occurred.:
Cookies do not appear to be enabled on your browser client. You will not be able to install the application with this feature disabled. Alternatively, there could also be a problem with the server's session.save_path. If this is the case, please consult your hosting provider if you don't know how to check or fix this yourself.
Message 1 of 4
(3,637 Views)
3 REPLIES 3
Re: Joomla Install Session Save Path error
27-10-2010 10:53 PM
I wonder if the problem is /var/lib/php5 is full? That seems to be session.save_path on PAYH.
David
Message 2 of 4
(337 Views)
20-05-2011 10:40 PM
Ok so I just had the same problem - I messed up my Joomla test site which was working last week - have repeated the installation process and get this same error message.
Hope you can help me sort this.
Quote Cookies do not appear to be enabled on your browser client. You will not be able to install the application with this feature disabled. Alternatively, there could also be a problem with the server's session.save_path. If this is the case, please consult your hosting provider if you don't know how to check or fix this yourself.
Message 3 of 4
(337 Views)
21-05-2011 1:02 AM
There are suggestions in this (external link) thread that Plesk might not get on too well with this package.
Also have you tried using a different browser (specifically Firefox)?
David
Message 4 of 4
(337 Views)
- Everything else
