Joomla 1.5 requires "index.php" suffix
- Everything else
- Joomla 1.5 requires "index.php" suffix
02-01-2008 2:46 PM
If I type ccgi.mydomain.plus.com/1.5_folder/ into the address bar on the browser the web site comes up without referring to the template style sheet. However, if I suffix it with index.php the site comes up perfectly.
This suffix is not needed with older versions of joomla, my other sites running joomla_1.0.13 go straight to it and displays perfectly.
Is there something I've missed? I suspect there is a work around possibly in the comprofiler but I don't know.
Any help will be appeciated.
Andy
Re: Joomla 1.5 requires "index.php" suffix
23-01-2008 11:56 PM
I have just worked my way through the Joomla SEF URL guide and I can get the home page to display, but I see the same problem you note about needing index.php. I also find that using most of the links on the web page result in 404 errors from Joomla. Yes Joomla, not the server, that gives a different 404 page.
From the sound of it you have SEF on. With SEF off I could not get as far as this, although it should be simpler and more straight forward.
I have been reading the Joomla forum posts for similar issues. One reason there might not be many sensible answers is that at least some of the problems are configuration / server dependant. I had a test site on my local PC using XAMPP and it worked perfectly. Transfer to plusnet and it did not want to play.
All in all, you seem to be closer to working than I am, but I'm still fiddling. Its a steep learning curve, but it looks worth climbing. I have a few ideas crystallising, but if you have worked out the basic settings for getting a working site, then I will try and spring board off that and let you know how I get on.
One question back to me on the Joomla forum was why are the PHP and MySQL versions on plusnet so old? I can't answer that. It might, or might not be important. If I can figure out how to use PHP5 rather than PHP4 then maybe I will find out.
Good luck
David
24-01-2008 12:19 AM
As you say, it is not happy with the plus net set up but I seem to recall reading on the joomla site that your own server is best for full funcionality. Shared servers are always a compromise. but we, the common user can't afford that! çe la vie
Formula: (Can [or 3] of Bass + Long Day) + Late night ichat and the like = Rambling on forum. G'night.
29-01-2008 12:47 AM
http://joomlacode.org/gf/project/joomla/frs/?action=FrsReleaseBrowse&frs_package_id=2
downloaded file
Joomla-1.5.0.tar.gz
2)
Uploaded file to root of ccgi
3)
Created new folder /joomla and put file into this folder
4)
Unpacked file with
<yourplusnetusername>@cshell01:~/joomla$ tar xvzf Joomla-1.5.0.tar.gz
5)
chmod folder joomla and content of folder to 755
<yourplusnetusername>@cshell01:~$ chmod -vR 755 joomla
6)
surfed to administrator page on browser
http://ccgi.username.plus.com/joo/installation/
7)
Followed installation guide
a)
Directive Recommended Actual
Register Globals: Off On
Can't change it anyway, and was discussed previously in the PlusNet forum. So clicked to the next admin page.
b)
Database Type mysql
Host Name humbug or rumpus
User Name your_PlusNet_username-as_in_email_from_PlusNet
Password as_in_email_from_PlusNet
Database Name as_in_email_from_PlusNet
Advanced Settings
set a prefix for joomla tables e.g. joomla_
c)
FTP not set
d)
Admin email-address and password
8)
Removed folder installation
Done to log in.
9)
In Admin > Global Configuration
set SEO to
Use Apache mod_rewrite Yes
and
renamed in folder /joomla htaccess.txt to .htaccess
(When surfing don't forget to clear cache with F5)
29-01-2008 10:52 AM
29-01-2008 1:28 PM
Quote from: Word ..still need to add /index.php to get template to work.
No such problem whatsoever.
I was curious about your experience and just installed Joomla (this is the final 1.5 version, not a Release Candidate). Everything works out of the tin!
Should it not address on your ccgi either index.php or index.html I would raise a ticket with PlusNet.
29-01-2008 5:17 PM
Just found this on Joomla site http://docs.joomla.org/Upgrading_to_1.5_Stable
Following on from previous comments:
try this:-
http://ccgi.frizzell.plus.com/nmrfu_cms/
then this:-
http://ccgi.frizzell.plus.com/nmrfu_cms/index.php
but 'index.php' is not needed on the same server with Joomla-1.0.13
Will raise a ticket pending your comments.
Latest info: Joomla 1.5.0 Stable (Kehpri) just installed, same problem /suffix index.php required to get page to open correctly with template(s)
NB: Nothing much to see on site as I haven't added any data yet.
29-01-2008 6:00 PM
Just put it into another folder on ccgi. For MySQL just choose another prefix for the tables during the installation process.
During
7)
On the last page click the button half-way down to populate the installation with sample files (for beginners like you and me important). Otherwise there wont be much to see and learn on the page.
Takes 15minutes.
(The problems on the links you give I believe has something to do with .htaccess and/or the URL not being properly set within Joomla.)
29-01-2008 6:10 PM
Can't think why it does this when 1.0.13 works as expected.
29-01-2008 6:21 PM
Why does on the page
your Home direct to
and there on the completely wrong page the Home direct to
Is there any other settings within Joomla where the URL is (wrongly) set?
Is there a .htaccess in root of ccgi?
29-01-2008 6:28 PM
29-01-2008 6:53 PM
29-01-2008 7:07 PM
I tried and tried and I am sure that is it:
There needs to be a .htaccess redirect in root of following kind:
RewriteEngine on
RewriteCond %{HTTP_HOST} ^ccgi.frizzell.plus.com$ [nc]
RewriteRule (.*) /nmrfu_cms/$1
Would you be so kind to try that for me and put this new .htaccess directly into root, and then just surf to http://ccgi.frizzell.plus.com .
I have a domain redirect into the folder /joomla , this is the reason why it works (http://www.mydomain.tld). However, with a ccgi.username.plus.com/joomla it produces the same problems you have. I guess, Joomla needs to go directly into the root of ccgi for the simplest of installation. And when we put it into a folder we need to do a redirect into the folder.
YES: it works. Checked it myself (small change in .htaccess done).
Please tell me if yours works.
29-01-2008 8:26 PM
The tests you suggest will have to wait till thursday now as I have to go away tomorrow and I have to have an early night tonight.
Thanks for your help, will hook up when I'm back.
30-01-2008 5:14 AM
Quote from: ffupi Gotscha!
There needs to be a .htaccess redirect in root of following kind:RewriteEngine on
Found a few minutes this morning but it doesn't Work. Getting :-
[font=Verdana]Internal Server Error[/font]
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, support@plus.net and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
It also screws up the other cms folders.
It's 5.15 am and now have to get to London, Bye.
Quick edit: I've deleted the .htaccess folder in the root now.
- Everything else
