Is telnet still available?
- Everything else
- Re: Is telnet still available?
18-12-2010 2:06 PM
Long-time user but not attempted telnet connection before. Searching the forum suggests that telnet used to be available and there were no special requirements, but attempting to connect to my CGI space with the Windows tenet client using:
[tt]Microsoft telnet> open ccgi.jakeman.plus.com[/tt]
just leads to "Connect failed". Asked for PlusNet support on Wednesday but no reply yet (It's Saturday today).
Is telnet still available? Is anyone currently accessing their CCGI space with it?
Thanks,
Chris
Thanks,
Chris
Message 1 of 5
(1,025 Views)
4 REPLIES 4
18-12-2010 2:10 PM
Telnet access to CCGI was disabled in August 2009 due to security implications I believe
Message 2 of 5
(453 Views)
18-12-2010 2:54 PM
That's correct. Which, of course, precludes actions entered on the command line including interactive scripts. Options are to use an FTP client and/or running bash shell scripts through the web interface to your ccgi space.
David
Message 3 of 5
(453 Views)
18-12-2010 8:45 PM
Hi Oldjim and spraxyt,
Thanks. That's exactly what I needed to know and I can work easily enough with a bash script .
Why is it so difficult to find this out? Have I missed an essential summary of the services available to customers?
Thanks again,
Chris
Thanks again,
Chris
Message 4 of 5
(453 Views)
18-12-2010 8:48 PM
I just did a search on the forums for "telnet ccgi" as I couldn't remember when it was disabled.
AFAIK it isn't documented
Message 5 of 5
(453 Views)
- Everything else
