Inserting file for my webpages
- Everything else
- Inserting file for my webpages
24-01-2013 1:49 PM
I am creating a webpage. That is easy enough, but what I have never done and need to do is insert a PDF file. How do I create a link for a PDF file that I have created? Do I have to load the PDF to a separate folder and what would be the link to allow people to download it? Looking forward to your answers
Tony
Tony
Message 1 of 5
(1,185 Views)
4 REPLIES 4
Re: Inserting file for my webpages
24-01-2013 1:57 PM
If you just copy the file anywhere in your webspace and then give a direct link - I assume you don't want it to be found by people browsing the site
The link would then be www.mywebspace.co.uk/file.pdf - if it is in the root directory or www.mywebspace.co.uk/folder//file.pdf if it is in another folder
Message 2 of 5
(295 Views)
24-01-2013 2:10 PM
Thanks, but it seems not to work. I feel that I am going to have to set up an account where I can keep online files. So that is the route I am taking. When it works! Keep plodding on
Message 3 of 5
(295 Views)
24-01-2013 2:19 PM
Is that the Plusnet website or another one
Message 4 of 5
(295 Views)
24-01-2013 3:02 PM
I will use my dropbox account. Then add the link that way
Message 5 of 5
(295 Views)
- Everything else
