Included .co.uk?
- Everything else
- Re: Included .co.uk?
Included .co.uk?
09-01-2014 1:33 PM
Am I right in thinking the business broadband includes the registration of 2 .co.uk domains in the price?
In which case does the plusnet control panel allow delegation to external nameservers as I'd want to use my own hosting.
Message 1 of 8
(1,427 Views)
7 REPLIES 7
10-01-2014 11:11 AM
No, unfortunately the name servers would need to stay with us. It's a limitation of our domain control system.
Message 2 of 8
(602 Views)
11-01-2014 10:33 PM
Oh well,
Can't think of any .co.uk's worth registering at the moment anyway and I'd not want to move my existing domain.
Message 3 of 8
(602 Views)
11-01-2014 10:52 PM
dragon if you want to register your own domain use 123-reg and then assign the nameservers to afraid.org (you'll need to sign up).They give you very extensive control over your DNS meaning you can change A records (IP address of your server) in a flash rather than changing nameservers again etc.
Message 4 of 8
(602 Views)
11-01-2014 11:26 PM
I actually have my own nameserver
I used to have 3 hosted on completely different networks, but it worked out cheaper/easier to outsource the redundant servers to a DNS hosting provider.
That said It depends what the domain is pointing at as to if I bother to use Redundant nameservers or point the domain at the same physical box for both primary and secondary DNS.
For my domains that I use email on then it absolutely makes sense to have multiple name servers to avoid losing email if the primary goes down but for some of my others they could fall off the internet for a week or more and it would be no great loss.
Edit:
I was only asking about the domains on the off chance I wanted another .co.uk, I'd normally use someone else to register my domains but I think I get 2 included with the broadband.
Edit:
Message 5 of 8
(602 Views)
12-01-2014 3:22 AM
I use a mix of hexonet (because they're the only .co.uk registrar I've found that will let me set IPv6 glue) and Fasthosts (can't remember why, but I fell out with 123-reg for some reason, possibly because they didn't let me assign more than 2 DNS servers per domain).
Message 6 of 8
(602 Views)
12-01-2014 4:28 PM
Quote from: avatastic hexonet (because they're the only .co.uk registrar I've found that will let me set IPv6 glue)
See also Mythic Beasts.
Gabe
Message 7 of 8
(602 Views)
12-01-2014 5:02 PM
Message 8 of 8
(602 Views)
