Hi
I have been using the provided frontend for the Humbug server and importing a CSV file into a table, all has been working. OK
I have now tried to reimport and I keep getting the error
"No data was received to import. Either no file name was submitted, or the file size exceeded the maximum size permitted by your PHP configuration. See FAQ 1.16."
I have tested it with different CSV files, Different computers, Different internet connection, and have also created a new table
The CSV file is only about 1.5K so its not a size problem, and as I have already said it worked about 3 weeks ago.
please Help
Ptanser
