Images and Background not showing
- Everything else
- Re: Images and Background not showing
22-03-2013 11:17 AM
Hello,
I am currently trying to host my first website and i am having some issues.
I have uploaded all my documents to the ftp folder but my website is only showing the text and links, no images or background layout.
www.trottersdrywaste.co.uk
When i go to http://www.username.plus.com/ the full website shows.
Can anybody help with this?
Thanks.
Thanks.
Message 1 of 5
(1,258 Views)
4 REPLIES 4
22-03-2013 11:23 AM
I would suggest you check the location of the external stylesheet file CSS.css.
The web page is looking for it in the parent folder of the home page but it doesn't seem to be there.
Message 2 of 5
(420 Views)
22-03-2013 11:23 AM
It is probably because you haven't made the links point to the correct place from that website
This is an example from your site
<p><img src="../../Images/Photo 22-04-2012 14 33 02.jpg" width="655" height="437" alt="image" /></p>
Message 3 of 5
(420 Views)
22-03-2013 11:26 AM
It looks like the domain seems to point to a random folder where as username.plus.com is pointing to the default index.
Also just as a heads up I noticed a few URLs with spaces and capital letters so I'd adivse sorting those out too especially if there's any you're trying to link to that aren't working.
Adam
Adam
Message 4 of 5
(420 Views)
22-03-2013 11:48 AM
Thank you all for your help, i seem to be getting somewhere now, think i've been looking at it too long.
Message 5 of 5
(420 Views)
- Everything else
